So is it realistic to hope for gains of a stone of lean mass per year, given decent diet + training?
In most cases, almost certainly not - in yours, it's do-able giving you should be growing and getting some natural hormone boosts as well.
Ok thanks for clearing that up, it's just that I read that realistically the body could synthesize 0.5 pounds of muscle mass per week. Which works out at 1.8 stone per year. And in the sticky it says that you should be gaining 1-2 pounds a week.
Mutated_Hair over at the myprotein forums was a similar build to you and he's put on 2 stone of lean mass in about 7 months following Stronglifts 5x5.
If you have a well structured routine and eat properly, you could easily gain a stone or more in your first year.
Chins (i.e. suppinated grip, palms facing towards you) ...
I always thought chins were suppinated (and usually closer grip) and pull ups were pronated. I guess just because I imagine your chin going up and over the bar in a suppinated grip, but not in pronated.Bugger, I meant pronatedAnd this from someone who knows a lot about exercise!
Anyway, chins which should be done pronated are better for lat, rear delt and trap activation. Pull ups (suppinated) are a good secondary version but are much more bicep dominant.
In essence: WG chins are over hand grip wide grip = more back activation
CG chins are underhand close grip = more bicep activation
