I have a gas boiler to supply my heating and hot water. According to the manual, the ideal system pressure is 1.0 bar but it has been hovering around 0.7-0.8 bar for a while which is within the safe limits.
Tonight I bled the radiators and the system pressure has fallen to 0.4 bar and as a result the boiler won't fire up. It needs to be at least 0.7 bar to work.
There is a tap underneath the boiler to pressurise the system but when I turn it nothing happens. It doesn't feel or sound like any water is flowing and the pressure gauge doesn't move.
Can anyone suggest why it won't pressurise? I need hot water for a shower in the morning and as it stands I'm screwed!
Thanks
Thanks
