- 16 Oct 2009
- Bonnie Scotland
Ive seen the wifi car q asked on various other forums, what advantage would that offer over the std installed card?
Draft 'N'
Asus 1008
No Ion but who needs an HDMI output on a netbook
Height: 18mm-25.7mm
Weight : 1.1kg
http://eeepc.asus.com/global/product1008ha-spec.html
I do
I take my netbook everywhere so showing off my BluRay rips on the go will be pwns and also when people see the size of the netbook and the picture quality it is outputting on a HDTV it will floor them![]()
the clip took 30 seconds to cue up
According to the review you posted above it took 30 seconds to stream the HDMI output.How do you mean by waiting around?
From OcUK? If not, exact same model?
Asus 1008
Height: 18mm-25.7mm
Weight : 1.1kg
[img ]http://www.yugatech.com/blog/wp-content/uploads/2009/03/asus-1008ha.jpg[/img]
Just phoned HP and they told me a Windows 7 version (with N280) IS coming out in the UK, but they don't know (or wont tell) when. Don't know what to do now! Argh!
Of course, then there is the new Samsung X120, dual core, comes with Win7 Home Premium lol![]()
ASUS Eee PC 1201N looks the daddy to me. N330 Dual Core, Ion, 3GB RAM, 320GB HDD, Wireless N and Windows 7, what a beast. Only problem is that I can order the HP one for £274 delivered today, bargain. No time frame or pricing for the ASUS but it doesn't take Batman to figure out it will likely be more expensive.
must . . . resist . . .
