Has ANYONE in this thread installed using the bought and paid for physical DVD for the extra £9?
I dont think there are any official ones, I'll post mine when they finish calculating.Someone post the MD5 checksum hashes of the downloads. That would be helpful.
Sure thing.
Basically you do get those files from the expanded setup folder:
Boot
EFI
sources
support
upgrade
autorun.inf
bootmgr
bootmgr.efi
setup.exe
Then you need to get hold of (google it) OSCDIMG.EXE
And then run a command similar to the below:
Oscdimg.exe –u2 –bC:\<path to expanded setup folder>\boot\etfsboot.com –h C:\<path to expanded setup folder> C:\Win7_ISO_OutputFile.iso
You should use the OSCDIMG.exe method above and not attempt this with ISO creation software as it will be unlikely to create it properly due to the non standard ISO comformation in the efsboot.com file. However, I believe using vlite may work according to a quick google from version 1.1.6. Above method will be best though.
I doubt that anyones DVD will have arrived yet.
I think this is the issue. Eveyone in this thread is tryign to clean install through the download method, something the download method is clearly not designed for. What we need is someone with the physical disk to install it to see what happens.
(My) CheckSums:
setup1.box
CRC32: 192DDFDF
MD5: 7B29E21B7F6BC0850E65085205B5EAFE
setup2.box
CRC32: 35D27FBF
MD5: 87DCC913A7BBBFCFA2C2526C2E894F97
Win7-P-Retail-en-us-x64.exe
CRC32: 4AC9D976
MD5: 73D13A1000069E372F7478CF1C426B7A
It's probably me not understanding fully about what you're saying so I apologise. Thanks for getting back to me though.
Yes, you're really purchasing a particular license of a Windows product. Though, weather the media you receive and the digital download reflect the license type to stop people that have purchased a Windows 7 Upgrade license to then freely be able to install Windows 7 on a brand new system, I'm not entirely sure.
Like I said in my post here, Microsoft should be putting measures in place. How they are going about it though, I'm afraid I am not entirely sure. Though, this isn't to say that there wont be any workarounds which there seems to be since a few people are installing Windows 7 on a system which hasn't got either Windows XP or Windows Vista installed.
Don't suggest people are crooks with no evidence. Next time I won't be so polite.
You're a crook!
What I have said directly above should answer your question.![]()
