Windows 7 Retail
14 Sep 2009
Northumberland
I bought this in the pre-order.
Can I install the 32bit on this PC, and install the other 64bit on my gaming PC?
Or do you need two codes?
1 licence per PC to run 1 CPU so if you want 2 then buy new licence to run other PC -- the retail box that MS put 32 and 64 that give you to choose which one to install not by 2 install at same time.
all Windows OS are only per PC with 1 product code key for check all hardwares before accept by activation. You can upgrade any new motherboard,etc.. and reactivation again as retail version can let you
