Quick remapping question!
10 Mar 2003
Well I'm still considering getting the Toyota Avensis mentioned in another thread. But one thing I would like to do is get it remapped as a few friends at work rate it highly.
The Avensis I'm looking at is 116BHP - I just wondered what it would take it to, the rough costs and could anyone recommend someone around the Gloucester area?
Cheers,
M.
It'll need a turbo for a remap to make any real difference.
Turbo derv and turbo petrol cars remap reasonably well (a lot better with breathing mods) but anything else really isn't worth it.
Remapping on a turbo engine can work well.
Remapping an N/A engine is a waste of time, unless it is tuned quite well first (breathing sorted inc. exhaust, cams etc).
If you want more power on an N/A buy a bigger engine:)
I thought the Avensis 2.0 D-4 Diesel T SPIRIT was Turbo? According to certain websites (and I'm not going to pretend if I know this is correct) the BHP increase is around 20-30. Whilst not being a load it may make a difference mainly in economy as well.
M.
Well if I could find something that fitted my bill perfectly I would - the Avensis I've seen is very comfortable and very well kept (almost immaculate and I'm a picky swine) I can't find anything else I like, other than Audis and they cost an absolute arm and leg to find a good model.
It's not about making the car that much quicker it's more about making it more economical as well. I intend on having the next car I get for a good while and as I do a fair few miles it all saves cash.
M.
M.
I've no idea if it is or not, just simply saying as a rule of thumb, turbo = good remap, N/A = not worth it.
Wouldn't the OP be better off buying a car that's more powerful in the first place? Buying a 116bhp car to then spend a lot to get little in return sounds like a false economy to me. Sure, it can be done but why do it?
Well it's more about finding the right car mate. I do like the Toyota for reasons I've posted but I'm more than open minded at finding something else. £6k is my budget. Diesel would be my preference due to mileage, etc.
i just brought a Skoda Fabia VRS 54 plate for £4500 and its awesome, cheap to run and pretty nippy as standard, itll remap to 160 - 170bhp and do 50mpg!
If you can get over the fact its a skoda (vw) it would be perfect for you unless a bigger car is required.
No not really I used to have an Octavia Estate until the neighbour mistook the break for an accelerator. I'll have a look around for one and see if I can test drive it....
Anything with the VAG TDI130 engine in is worth a look. So that's Golfs, Leons, Toledos, Boras, Passats as well.
Remaps to 170bhp IIRC.
