This Week Only 28/10/2009
17 Oct 2002
Stoke
*** *** Antec 902 Nine Hundred Two Ultimate Gaming Case - Black (No PSU) @ £86.99 inc VAT *** ***
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Only £86.99 inc VAT.
ORDER NOW
*** *** Asus Rampage II Gene Intel X58 (Socket 1366) PCI-Express mATX DDR3 Motherboard @ £169.99 inc VAT *** ***
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers. With the Rampage II GENE, ASUS has masterfully filled the mATX gap in its lauded ROG product line. For the first time, users will be able to harness the full power of the Intel® Core™ i7 processor in a chassis the fraction of the size and weight of an ATX desktop PC. The Rampage II GENE’s awesome combination of overclockability, tweakability and stability enable it to easily outgun other full-sized ATX motherboards.
- CPU LGA1366 socket for Intel® Core™ i7
- Chipset Intel® X58/ICH10R
- System Bus Up to 6.4 GT/s with QuickPath Interconnection
- Memory 6 x DIMM, Triple Channel, up to 24GB
- DDR3 2000(O.C.)/1800(O.C.)/1600(O.C)/1333/1066 MHz
- Expansion slot 2 x PCIe2.0 x16 slot, supports dual x16
- 1 x PCIe2.0 x4
- 1 x PCI 2.2
- Multi-GPU Support NVIDIA SLI™ / ATI CrossFireX™
- Storage 7 x SATA 3.0 Gb/s
- 1 x eSATA 3.0 Gb/s
- 1 x UltraDMA 133, support RAID 0, 1, 0+1, 5, and JBOD
- Gigabit LAN
- Audio Onboard SupremeFX X-Fi 8-Ch. Audio with EAX4.0 support
- Other I/O ports 1*PS/2, 1*eSATA, 1*IEEE1394a, 1*Clr CMOS, 1*Optical S/PDIF
- USB / IEEE1394a 12 x USB2.0 (6+6) / 2 x 1394a ports (1 at back I/O, 1 onboard)
- Fan connector 5 (1 x CPU / 2 x Chassis / 2 x Optional)
- Software (Full version) Kaspersky anti-virus, Futuremark® 3DMark™06 Advanced Edition
- Features MemOK!, CPU Level Up, Keyboard-TweakIt, Extreme Tweaker, iROG, Loadline Calibration, LCD Poster, EPU-6 Engine, Q-Fan plus, Voltiminder LED
- Form Factor mATX Form Factor, 9.6”x 9.6” (24.4cm x 24.4cm)
Only £169.99 inc VAT.
ORDER NOW
*** *** Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) @ £59.98 inc VAT *** ***
The Corsair Cooling Hydro Series H50 CPU Cooler gives you the power of liquid cooling in a compact, easy-to-install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
Air-based CPU coolers simply aren’t as efficient as water coolers, and can take up too much valuable space. The compact, closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Supports LGA775, 1156, 1366, AM2, AM2+ & AM3
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Only £59.98 inc VAT.
ORDER NOW
*** *** Palit GeForce GTS 250 1024MB GDDR3 PCI-Express Graphics Card (Includes World of Warcraft Trial) @ £80.99 inc VAT *** ***
The Nvidia GeForce GTS 250 graphic card delivers world-class HD graphics performance plus GPU-accelerated Nvidia PhysX gaming effects, lightning fast video and image processing, and full Nvidia 3D Vision support allowing you to game in true stereoscopic 3D. Experience world class graphics performance in the hottest games of this season and bring your games to life with Nvidia PhysX effects for massively destructible environments and ultra-realistic physical interaction in games. Accelerate video transcoding of digital movies to your iPod, PSP, or Zune up to 10x faster than a CPU. Experience super fast, silky smooth image processing with full GPU acceleration support for Adobe Photoshop CS4.
- Core Clock: 738MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1100MHz (Effective)
- Memory Interface: 256-Bit
- Memory Bandwidth: 70.4GB/s
- Processing Cores: 128
- Shader Clock: 1836MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Game Information
Buy any qualifying NVIDIA® GeForce® 9800 GT or NVIDIA GeForce GTS 250 graphics card and receive one FREE digital download of the complete World of Warcraft Classic game.* This download is a full install of the complete retail version of the game with unrestricted 30 day access to character classes, cities, quests, chat, and other features from World of Warcraft Classic. For details, go to www.nzone.com/WoW.
*World of Warcraft is a subscription-based game. To continue after the first 30 days, players must enter into a monthly subscription agreement with Blizzard. Voucher valid until November 30, 2009 or while supplies last. Terms and conditions apply.
Only £80.99 inc VAT.
ORDER NOW
*** *** "Ultima Bloodrage" Intel Core i5 750 2.66Ghz @ 4.00GHz+ DDR3 System @ £1,034.99 inc VAT *** ***
Featuring an overclocked Intel Core i5 2.66GHz processor overclocked to 4.00GHz and beyond there is little that will trouble the Ultima Bloodrage. The ATI 4890 graphics card push the very latest games to new heights, you will be able to see every blade of grass or reflection in the water as you travel on your gaming adventures. The 4GB of 2000MHz Dual Channel memory you will never have to have a break in the action no matter how many programs are open or how intense the action gets. With a menacing all red design in the Coolermaster HAF 932 case the Ultima Bloodrage will intimate the competition and give you the crucial edge be it online or at LAN gaming.
Key Features
:- Latest Intel Core i5 technology to push the boundaries of PC performance.
:- Overclocked to get the most performance for your money.
:- Low noise allowing excellent movie playback through HDMI / DVI.
:- Massive upgrade options with Crossfire capability and space for extra hard drives.
:- Only the highest quality components ensuring the highest levels of reliability.
Key Components
:- Intel Core i5 750 2.66Ghz @ 4.00GHz+ Overclocked Processor
:- Asus Maximus III Formula Intel P55 (Socket 1156) DDR3 Motherboard
:- G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit
:- LG CH08LS10 8x Blu-Ray Reader/16x DVD±RW
:- Corsair TX 750W ATX2.2 SLI Compliant PSU
Note - Specification not exactly what you are after? Drop our friendly Sales Team a call on 0871 910 9101, they will be more than happy to help you make your perfect system.
Note - All systems are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours. The system can be supplied assembled with or without your choice of installed operating system but is supplied without keyboard, mouse, speakers or monitor (all of which are available elsewhere in this on-line store).
Only £1,034.99 inc VAT.
ORDER NOW
The Titan Goliath does not look to be that great a deal this week. Was £727.98 but this week only deal is £743.96 - not too big a saving on that one!
I remember when the Antec TruePower 500 was put on This Week Only but it was the same price as I had seen two days earlier :P
Idd you would have to tad foolish to think your getting a deal most DOTW but times are hard so maybe just protecting there profit margins, you dont get to drive a supercars being the cheapest lol. On a serious note Ocuk do do good deals every now again like that gtx280 flurry £229 when they were so expensive else where, swings in roundabouts i guess :)
Great I was hoping the Antec 902 wouldn't go back up in price since last weeks deal on it, but it's gone down even more!! Got this aswel as the H50 cooler with my build.
Only wish the G15 keyboard could have been in the this weeks deal.
EDIT: Ordered an XFX 4890 because the 4870 was out of stock a few hours ago, now its back in stock. Lost £50 there. :(
It's all a Rip Off no matter what you say. Rip Off britain. And you can argue till the Moocows come home about the fluctuation of the pound. The reason we got in a mess in the first place was because of Greediness where they wanted us to pay high prices. It's still the SAME. It's the Truth.
If the prices droped realisticly then more will buy. I won't buy at these High prices. I'll wait till the moocows come home.
the Corsair H50-1 High-Performance CPU Watercooler
says it was £ 64.89 and now £59.98
that means it hasnt gone down because it was 59.98 yesterday
