Evening...
I'm in the middle of speccing up a new gaming rig... Now I need to sort out a case..
Priorities: SPACE & COOLING.
Space; Needs to accomodate a high end GPU and 1 of the following;
1. Corsair H50-1
2. Prolimatech Megahalems Performance CPU Cooler
Cooling; Additional fans for the best cooling possible and good air flow.
I won't be spending mega bucks on 100+ fans in the case to bring it to sub zero's temps.. Just enough to keep it healthy.
I'm fancying the CM690 but that's a little over the £50 I'd like to spend.... Possibility though.
So what can you recommend for around the £50 mark with the above criteria?
Also, is a psu at the bottom of the case going to interfere with any of the above 2 cooling solutions?
Many Thanks, Rhys
1. Corsair H50-1
Many Thanks, Rhys
