Battery Relocation..
27 Aug 2003
West Midlands
Hey all,
Thinking of moving my battery to the boot to make some space for something up front. What's involved? I've currently got 2 or 4 (can't remember..) gauge power cable running down the car for my subs, I doubt this would be thick enough? Not entirely sure though...
Would I need any fuses anywhere? I imagine distribution blocks may be necessary?
Cheers for your help.
ScoobyDoo69
It's not generally considered normal practice to fuse the live when running a battery from the boot.
Been running mine from the boot with 25mm cable (135amp) just fine for months now. It isn't fused and it doesn't get warm. All the positives join in an electrical box. I dont have a negative lead going to the battery as i just earth it through the shell but i will be doing that when i have the chance :p
True - but you can get circuit breakers which allow a peak current for a number of seconds and will then open. Don't think I would fancy running a cable from the battery in the boot to the engine without it being protected somehow..
Thousands of rally cars out there with batteries in the boot and no fuse.
I've helped prep scores myself and none of them had fused lives, but I can understand your reasons for wanting to do so.
This is actually something I plan to do myself in due course so I can fit a FMIC to my 200sx.. Running without some sort of protection scares me - short circuits are not good!!!! :D
I believe DB-Power do some sort of kit which includes a circuit breaker so I think I will just go with that :).
I ran my car for ~9 months without a fuse, then decided as a safety precaution to fuse it.
I cranked my car over repeatedly with the 150A inline fuse and never had a problem. They aint cheap though, the fuse and holder set me back £30 as i wanted something semi decent!
Good god get it done! :/ Engine and electrical systems will miss the electrons being so close, instead of finding a path through the shell.
The Mini (proper one) came from the factory like this, as did several other cars of the era.
I have an awful memory of a friend of mine with a Mini who left the battery cover off and had a metal petrol can in the boot. You can imagine where the story ended up - to be fair to him he managed to put the fire out (by stupidly opening the boot and throwing the petrol can out) with the only real damage being some slightly melted 6x9s. :eek:
I dread to think what would have happened had that can been full.
Fuse wise, cranking will draw more current than most shorts will, a fuse is pretty pointless.
Just need the existing fuses where other circuits break off the hot terminal.
Little plastic terminal caps, or a battery cover would have sorted that :p
A proper short has close to zero resistance going through the chassis and the battery goes into full discharge. Your starter wont draw anymore than 100amps.
Most the stuff I worked on had fuses, including the 12v charge output from a 24v BISG system having a 300A fuse.
