Hi All
I am running Win7 RC with an old Nvidia 6600 .I went to play command and conquer ZH but the graphics were corrupt.I think its because the PSU is underpowered only 250W.
So i decided to get my old radeon 9200 all in wonder from my old pc.I installed it and went to install the Catalyst software from the disc but got nothing.
So i looked around online and found an old version of the CCC that had XP drivers for the 9200.Wheni went to install it though it says i need a standard VGA graphics driver before it will install.
I have checked on the windows settings and it says i have a standard driver installed.I have checked to see if there was a newer available but there wasnt.
So im at a bit of a loss.Does any1 have any ideas other than buying a new PSU.
The rest of the system is an old P4 and 768 Mb of Ram.
Thanks
Martyn
Thanks
Martyn
