[TW]Fox;15231601 said:
ESP does not therefore guarantee auto hill-hold.
I see. So all that can actually be said is that not having ESP, guarantees that your vehicle does not have hill hold. My BS is already on the first page of Google if you search 'dsg esp hill hold', a classic demonstration of why you should be careful of what's written on the internet.
It definitely had the ESP button, I know that for sure. I also know that it would roll back on hills too so the hill hold thing must be something different.
It's not something different as such. Hill hold can only be actuated through the ESP system. I guess they must have introduced a software upgrade or added an actuator in later ESP versions.
Another thing I just remembered that I didn't like was the feel of not knowing which gear you were in. With a manual box you move a gearstick into a certain place so therefore you know what gear you're in, with DSG you flick a paddle (or sometimes the box does it for you like I said above) so you have to keep an eye on the dash display to remember what gear you're in.
Why do you need to know what gear you're in? You just need to know you're in the right one, which can be easily detected by the engine noise and the feel of the car when accelerating.
What about rally drivers driving cars with sequential gears? Aside from the fact that they probably know intuitively what gear they're in, the only way they know for sure is by looking at the display. I'm not comparing your average DSG equipped vehicle to your average rally car in terms of either equipment or driving experience, but surely they don't have time to keep checking their display to make sure that the gear they've selected is the most appropriate.
I know from when I use the paddles that you can easily tell whether or not the most appropriate gear is selected. It is however annoying that it reverts to auto mode if inactivity is detected. I'm not sure if putting the gear lever into manual mode also, overcomes this. Will have to check later.
Back on track, I sincerely doubt that manual boxes will be of interest to anybody once production costs come down to the point where they can be included in the cheapest of mass production cars, and where they improve to the point that manual fans perceive that sufficient control can be exercised through them.
