- 22 Aug 2005
- Clydebank
just to go back a step... Are you sure you have upgraded the firmware?
from another forum said:To do the above I
Downloaded the firmware script by itself:
http://git.kernel.org/?p=linux/kerne...rmware;hb=HEAD
And then Save Page As
"get_dvb_firmware" - without quotes
Change directory (cd) to the folder where you saved it
Now in terminal use
perl get_dvb_firmware tda10046
Copy the resulting file ( dvb-fe-tda10046.fw ) to /lib/firmware
sudo cp dvb-fe-tda10046.fw /lib/firmware
root:/lib/firmware
ls
dvb-fe-tda10046.fw
dvb-fe-xc5000-1.6.114.fw
dvb-usb-dib0700-1.20.fw
what is your other TV card?
I really don't get it when I searched on the web other people have got my HVR 1100 Haupague working on ubuntu but I don't get how they did that.
Still a learning curve for me though.
As you can see the firmware is in that directory
but so are two other dvb ones
so what do you think I should do?
Hauppage HVR-3000 I got this working months ago, even BBC HD but the picture was a little rubbish compared to windows.
I'm doing my teacher training so can't waste weeks trying to force it to work.
Although Windows 7 is being a pig about dual tuners atm.
root@parm-desktop:~# dmesg | grep fw
[ 6.514515] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[16] MMIO=[febfe000-febfe7ff] Max Packet=[2048] IR/IT contexts=[8/8]
so what does that show u?
shall I remove the two other dvb files to another location?
windows 7 dual tuners?mmmmm
what is the problem?
I'm soon due to try setup my
hvr 1100 and compro video mate card on windows 7
mmmmm
>i'm not sure if your card has an onboard signal amplifier, if you find you cannot pick up any channels when you scan it could be worth trying it:
wget http://www.wi-bw.tfh-wildau.de/~pboettch/home/linux-dvb-firmware/dvb-usb-dib0700-1.10.fw
sudo gedit /etc/modprobe.d/options
>(then add the line)
options dvb-usb-dib0700 force_lna_activation=1
sudo modprobe dvb-usb-dib0700
>reboot then:
dmesg | grep dvb
parm@parm-desktop:~$ dmesg | grep dvb
[ 14.709570] cx88/2: cx2388x dvb driver version 0.0.7 loaded
[ 14.709572] cx88/2: registering cx8802 driver, type: dvb access: shared
[ 135.153402] usbcore: registered new interface driver dvb_usb_dib0700
i have givewn up with linux on my HTPC, just installed win7 on it and about to order a dreambox to get me sky on HTPC.
