14" is an awkward size for semi sporty tyres, as I found out when buying new ones for the Manta. Most stuff is 15" upwards so you have to think outside the box a bit.
I prefer Yokohama A509 as the sidewalls are stiffer. That said, I've had the ZE912's on the Manta for a couple of months and no major complaints. On a light car like the Manta (or your 205) they certainly aren't "highly renowned for being garbage", in fact from all the reviews and testimonies (proper tyre reviews as Fox will tell you are often hard to come by) seemed to be middle-ground at worst.
For my liking the sidewalls are a little bit squidgy, other than that I can't really complain. Wet and dry performance is good, if anything too good in the wet for my liking (which means I actually just need more power)
Fox, they aren't "well cheap m8", they are about the average for a tyre of this size.
The ignorance on this forum is really astounding at times. The guy is buying FOURTEEN INCH tyres, he cannot simply go and get Vredestein Ultracs, Toyo Proxes T1R, Falken 452s, Goodyear Eagle F1s, you just don't have that sort of choice in this size.
