- 30 May 2007
- Glasgow, Scotland
Hey mrk, how long did your phone take to reboot with the new updates applied? Mine has been going for ~15 minutes rebooting and starting to get a little worried :S
//edit : - Gave up with the new update, not sure why but it would not boot after applying the files linked here :http://forum.xda-developers.com/showthread.php?t=568032
Should I be using a different set of files as I am not used to doing these updates yet either![]()
As mrk said above thats the wrong ones, the 32a. Your looking for the ones on this page http://forum.xda-developers.com/showthread.php?t=567610
Takes no time, i think if your on anything above 4.2.2 you can just flash with newer versions, no need to do the 2 stage thing or wipe all data/settings.
If it helps, this is what i done (not sleepy enought for bed yet lol)
-Papped the 4.2.3.1 zip on the memory card (and the sound resources, fed up of the same ring tone!)
-Switch off
-Home and power button till the boot menu shows
-Nandroid backup 2.2
-Flash with any zip on sd card, and selected the 4.2.3.1
-Gave it a minute...
-Done, so i selected reboot
-Phone booted, takes a bit longer than usual... maybe 1-2mins on the animated android screen.
Job done
Might help, might not lol!
Back to more House MD for me
woo!
