Windows 7 - Winamp problem
Caporegime
9 Mar 2006
Surrey
I now get an error when I try to edit the tags of files in Winamp using the edit selected items menu option. The following comes up:
"Error updating file: D:\My Documents\My Music\Various Artists|Where's Neil When You Need Him\Coraline 2.mp3"
Anyone know how I can fix this?
If you've got UAC enabled then indirect file changes may be blocked. Disable UAC or load WinAMP with Admin rights (right click properties and always start it as Admin).
The latter is the wiser option unless you're 100% confident in your web browsing habits and what you run/install :)
This is what scares be about upgrading from XP to Windows 7. As I use a version of winamp from 1999 (2.5e) I have a funny feeling its not even going to run it at all. Might clone my drive and try the upgrade uption tonight, then if everything doesnt work and can clone back and all will be good
You'll have to disable UAC to get rid of the box :p
This is why I don't use UAC, but I am quite confident in my maintenance-fu skills =]
the program shouldn't require elevated rights to write tags to files in a proper user folder like "my documents". it's no different to editing any other file type. you wouldn't go to such lengths when using word or mspaint would you?
Well what choice do I have?
Perhaps I'll just disable UAC, I'm pretty careful with stuff I install.
Fire Wizard may be able to offer a solution, maybe :p
Other than that though I've never had a machine be compromised due to UAC being disabled.
It's too much of a pain being enabled on my machines, SMART monitoring in Speedfan for example, even once elevated, does not completely work, SMART attributes display for example but temp monitoring fails.
I can edit tags in Winamp without elevating it to admin rights, there's something more going on. I have Winamp stored in it's default location with me media files on another partition on my drive.
I'd check your D drive and check you actually have ownership of all the files.
I ran 2.9 on w7 last week. It was slow but it was usable.
Right click the folder(s) with your music in them, go to the security tab then the advanced tab and check the owner tab.
Thanks, it says:
Current owner:
S-1-5-21-515967899-1788223648-839522115-1004
Change owner to:
Shamikebab (Taniquetil\Shamikebab)
is that what it should be?
