Some last questions before I go ahead and do this!IF ANYONE WAS TO FOLLOW THIS INFO THEN I TAKE ABSOLUTELY NO RESPONSIBILITY FOR ANYTHING THAT HAPPENS TO THEIR PHONE. I MEAN IT, I REALLY DO TAKE NO RESPONSIBILITY.
Right. Read through this and the guide webpage multiple times and ask questions if you are unsure before commencing.
Download these files.
http://zenthought.org/system/files/asset/2/flashrec-1.1.3-20091107-2.apk
http://www.androidspin.com/downloads.php?dir=enomther/ROM/&file=HTC_ADP_1.6_DRC83_rooted_base.zip
http://n0rp.chemlab.org/android/update-cm-4.2.4-signed.zip
copy these from your computer to the root of your sd card.
then from this guide (the one you posted a few posts back)
http://wiki.cyanogenmod.com/index.php/Full_Update_Guide_-_MT3G/Magic_Firmware_to_CyanogenMod
start from step 10
"10. Start up your phone or mount the SD card, then run App Installer and install FlashRec from its APK."
at this point you either need to have the "App Installer" app or the "Linda File Manager" app installed so you can access "flashrec" on your sdcard whilst the phone is running. Once you've done step 14, carry on past the file download part, as the link's I posted are the files you need along with the most recent Cyanogenmod.
Jump past the file download bit to the next lot of steps
Flash Android 1.6 & CyanogenMod 4.2.x/4.1.99+
and since you would already be in the recovery screen ignore step 1 & 2.
However. Before doing step 3
DO A NANDROID BACKUP
3. Select "wipe data/factory reset"
then carry on till the end of that section
10. Wait. This will take a couple of minutes. Be patient!
How do I do a NANDROID backup?DO A NANDROID BACKUP
Do I need to place the zip file in root or unzip the contents of the zip file to root? I assume its the same as with the cyanogen mod file. Just put the zip there? Then when the cyanogen installs it takes care of the audio files for me?And yes, just unzip the audio resources zip to the root of your sdcard and then all the extra ringtones etc will be available to you.
I'm not rich and I have many emotions.Oh and one other thing. Unless you are rich, or have no emotions, you'll be crapping yourself all the way through this untill CyanogenMod 4.2.4 loads up. I know I was the first time I rooted and installed 4.0.4![]()
How does the phone download this? Does it do this over my Wi-fi connection? Or can I place it onto my sdcard at root to save some time?then it will download CyanogenMod 1.4 recovery which you then flash from flashrec.
OK. So it isn't possible, or there's no point, in downloading it before hand and placing it in root?Flashrec will download it via your wifi. It's only a few mb so won't take long.
That's all you had to say for me to download the file.You'd have to know the command line to type into the box to get the 1.4 recovery flashed.
Lol. So as long as I do this before Friday I'm ahead of you?I totally understand your hesitance as I had all the files on my sdcard for about a week before I just said "**** it" and did it.
Yeah I saw that somewhere. Here I think.Oh yes. When you try and install flashrec on you phone you'll most likely get a box up saying "oi what are you up to trying to install something that isn't from the market?". What you need to do is follow the pop up box that pops up and in the menu screen check "unknown sources". This allows you to install .apk files you get from places that are not the market.
My Mum was so impressed she said she was almost tempted to get one!!It is the best phone OS you will ever see![]()
