- 12 Feb 2003
What that one and not Taskiller? Taskiller is far more straightforward and easily accessable.
How can it be any more simple than starting the app and clicking kill?
[SKR]Phoenix;15325724 said:How can it be any more simple than starting the app and clicking kill?
Taskiller sits on your notification bar so you can open it easily - Doesn't Advanced Task Killer need to be accessed through the settings?
It can sit at the top of the screen too. Mine does.
[SKR]Phoenix;15327821 said:Yep it can. I don't leave it running though, I added it to the list of apps to kill. One tap of the icon, one tap of the kill button, done.
EDIT: isn't tapping an icon, then button easier than dragging down the notification bar and then clicking the button?
Do Orange brand this phone in anyway? I have an N82 with them and it has this really annoying thing on the home screen!
Am I the only one that hasnt needed TaskKiller since upgrading to the latest ROM? I do make sure I close apps after I finished using them rather than just bang the Home button.
Thats alright I can deal with the small logo, its just on the N82 I think it was orange who put this little menu style thing on the home screen which I have never used and it bugs me being there.
They have the Orange square on the rear case, although you can probably pick up a graphite rear from the bay if you wanted it to look unbranded.
Mine is totally unbranded... jackpot!![]()
The Orange logo on teh back cover is irritating, otehr than that it says Orange in very small text on the unlock screen but thats all you get in the way of branding
