 - 26 Aug 2004
 - Manchester
Having a surprising and disappointing amount of rage quits so far. :/
Getting the crash every minute aswell. Trying the new beta driver for nvidia. Redoing the validation etc several times. Redownloaded all the files a few times. Same issue am mighty peeved![]()
Anyone else have an issue with the OCUK servers appearing and disappearing every few seconds from the menu screen?
When you get on the servers everything works great though
 Can only connect to ones half way through a campaign.I've only had one blast so far, gonna have another go in a few mins. The map was good, but has anyone else noticed the annoyingly constant onslaught of zombies? It seems to do it on the 3rd or 4th map of the first campaign in particular, we would fight off a horde and literally a few seconds later we would get another horde. They weren't always huge hordes, but big enough that on expert we had to take shelter or pick a corner to survive. This went on for over half an hour, and there is no dramatisation to my post, literally horde after horde for 30+ minutes.
I hope that isn't an indication to how expert plays now. Tranquil suggested that they have simply beefed up expert mode, as we used to fly through it. I'm all for beefing up expert mode, but not at the expense of pacing.
Heh, I probably should have mentioned it wasn't an event, the constant spawn fest was not part of any set piece, we just got hordes one after another. After we finished one off we would hear the horde jingle again to let us know more were coming. It was the entire map, I think it was where you get into the mall for the first time that it really started going nuts. Maybe I'm blowing it out of proportion, but I'm a long time L4D veteran and I was getting frustrated at how we were not getting a single break.You were probably on the one where the alarm is going off and you have to get to the top floor to turn if off. Thats the reason the hordes just keep coming. The demo had one of them too if you remember. Im guessing theres a fair few of those type of situations.
