Argh winamp!
Man of Honour
15 Mar 2004
Liverpool
This serves as nothing but a rant - but why the **** is the "Crop Files" option right next to the the normal "Remove Item(s)" option?
One deletes so much more than the other, and as somebody who likes building up playlists...
Argh!
I don't mess around with playlists much but I have just tried those two options. You are right, I can see it being very Argh! indeed - especially if you just spent 10 minutes lovingly crafting the perfect playlist! :(
They should separate it or at least be gracious and give you a "Are you sure?" dialogue.
Argh!
Aye, the trouble is I had around 600 songs on that list. My last save was about 50 songs ago.
That's a good idea actually regarding the dialogue. I'll suggest it in their forums.
no undo/redo options? maybe you should try foobar. :p
You can't undo/redo that function. Does foobar have this?
