Can't hear them over the Corsair H50 setup!
Hmm thats a water setup right?
I got case fans and scythe ninja fan.... reckon they will drown the sound out?
Looking good there Tom, the more I see that heatpipe the more I like this cooler.
That is some awesome cable management..![]()
Is it really worth it im sure the x2 is just as fast a fair bit of the time?
If you think toms cable management is bad.. you should see my case![]()
All reviews i have looked at the x2 beats it in 2 or 3 games 5770s are better on most games.
 and less heat and noise I guess with DX11Why are you all using 2 crossfire bridges? Do you think it looks cool or something? .
It gives mildly better results IIRC.
Not sure if 2 of them would fit properly though. I have a antec 902 with the gigabyte x58 UD3R board. looks rather tight not sure i would get 2 in?
