- 14 Oct 2009
- Rotherham. S.Yorks
Thats amazing, you sir are a god amongst men, ive never seen a tower that good before
Down from 24k to 22k in Vantage but I haven't clocked it yet.
Very quiet in operation, very surprising!
Drivers are pants but hey ho.. they will get better.
I have turned off the central heating as it cannot compete with this thing![]()
Deadman do you have your 920 overclocked?
Quite surprise your SLI setup is quicker, I doubt you'll make up 2k in vantage through overclocking the GPUS?
I have mine behind the mobo tray between the side panel but stuck with duct tape, it peels off after a while and isnt all that neat, what can u recommend? If u wouldnt mind, can u take a picture of the back of ur case so i can see ur cable management?
Not sure about the OP, but I used little cable tie-downs and small cable ties. Just make sure you clean the surface well with something non greasy first. Works very well and is really neat...
http://i17.photobucket.com/albums/b88/Diggsy/IMG_0322.jpg
http://i17.photobucket.com/albums/b88/Diggsy/IMG_0424.jpg
the second link isnt working deadman, sais the result is either set to private or has been deleted
have you used the voltage tool to get it back up to normal voltages by any chance? supposed to fly when its been unlocked![]()
Installed the Sapphire HD5970 download version of their Redline utility and it says "Sorry, this tool is not supported on your graphics card"
Anyone else had this problem? I'm running Win7 x64 Home Premium
I went for the XFX Black Edition 5970 for this very reason of OC tools not working right.
