Looks good mate, from what I can see, your waiting for the waterblocks to become available for the 5970?
Indeed, apparently the EK block should be ready today but it will be a couple of weeks before stock hits our shores.
You think the block will be exspensive? From what I could see when blocks where available for other cards, around £100?
Any luck with the Afterburner app?
Any particular reason? Unstable? Perform badly?1st bit of advice, do not install the Beta Drivers from AMD.
Not sure about the OP, but I used little cable tie-downs and small cable ties. Just make sure you clean the surface well with something non greasy first. Works very well and is really neat...
I saw those cable ties on my travels the other week...And thought nah.
But after looking at the work you've done, I think I'll go and pick some of those up. Thanks for showing me how useful they really can be.
