- 5 Oct 2008
- Kent
guys how do you play on the ocuk servers ? ive no idea how to pick servers :s
simplest way is to create an autoexec.cfg file in your Left4dead2/cfg directory and add this line into it:
mm_dedicated_force_servers 94.23.222.136:29021,94.23.222.136:29025,217.163.30.155:27015,217.163.10.204:27015,94.23.222.136:29029,94.23.222.136:29033
Sometimes these forums have a tendency to add extra spaces so remove those for it to work, with the exception of the one between the command and 1st IP Address.
Another method is to go into console before creating a lobby and type the above in or sv_search_key ocuk
