- 5 Aug 2006
- Derbyshire
I have my rig (see sig) and want more speed from it.
However, an i7 build is out of the question due to funds.
My e6600 is at 333x9 currently. I don't really want to run 400x8 as my anything windows based aside from cpuz says it is 3.6ghz for some wierd reason.
At 3ghz the ram is still at 800mhz using a different divider and the cpu is nice and cool. Anything over 3.2ghz requires much more voltage and at 3.6 the temperature is around 75 and I seriously wonder how high intel burn test would send it!
At 3.6ghz around 1.4v (iirc) is needed and temps are ridiculous.
I have a cheap artic freezer 7 pro, which I cannot remove as the pins on it are broken and the next time it comes off it will have to be binned.
Should I be looking at a used 45nm quad at all?
Is 4ghz rather than 3ghz REALLY worth the effort?
Would this cooler made much difference? http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-ZA&groupid=701&catid=57&subcat=1395
I have a good motherboard but only 800mhz ram.
Thanks
EDIT: I am looking to increase performance but not waste money for a tiny difference.
Thanks
