Caporegime
- 8 Jan 2004
- Rutland
Does L4D2 gain much from having ATi Crossfire? I'm thinking of grabbing another 4870 second hand.
Are you having FPS issues? I can run it maxed on a 4890 at 1920x1200.
Yeah probably about 5fps.Does L4D2 gain much from having ATi Crossfire? I'm thinking of grabbing another 4870 second hand.
I get more than enough fps with a 4850 with max settings at 1920x1200, suprised you're even thinking of a second 4870 :|Does L4D2 gain much from having ATi Crossfire? I'm thinking of grabbing another 4870 second hand.
the regular expert realism games with midnight Steve and defrag are 100% awesome
We've just got swamp fever to do, and we need to redo hard rain i think.
Yey, i got my Guardin' Gnome achievement back.
. Do you have to score a certain amount of points to get it or what?suggestion: If people are not using vent and they need the SI to stop attacking it is very easy to miss stop at the side of the screen. It seems much more effective to use something like "***********************stop" as it a lot easier to spot. Im only saying this because 2 players RQ last night as they complained the SI didnt stop when asked. Hopefully something like this can reduce the misunderstandings
Get the Gnome, and finish the campaign with it (i.e. to the helicopter with it in your hand).What do you have to do to get the Gnome? I just came across it on a wall next to the shooting gallery and took it, then one of you lot incapped me 30ft from the safe house. Do you have to score a certain amount of points to get it or what?
Didn't you get stuck on the 2nd level of hard rain for 2 hours or so?
another... hahaOcUK 1 just went down and booted us all, after a 20 second hiccup moments before. You'd been offline for three minutes, Link
The only bad thing, was how my team was on a perfect round on the The Parish - max points for the first three turns![]()
pity about alltalk was on in the second server, although it made it kind of funny, ruined tactics for both teamsSuspicious was the word I would useTypical that it crashes just after I go offline eh?![]()
