- 3 Sep 2005
- Glasgow, Scotland
Not so much on the physical makeup of the brain more along the lines of higher function, this is quite interesting reading.
Its all a sequence of chemical reactions... think we have free will... think again.
What happened if for some crazy reason , the Spinal Chord began making up more commands then just your basic *quickly move hand something is hot* to Need to Survive at all costs , and an epic battle beteen the Spinal chord and the brain was to begin.
The Spinal Chord is a fast lane from the nerves to the brain.
A reflex arc is the neural pathway that mediates a reflex action. In higher animals, most sensory neurons do not pass directly into the brain, but synapse in the spinal cord. This characteristic allows reflex actions to occur relatively quickly by activating spinal motor neurons without the delay of routing signals through the brain, although the brain will receive sensory input while the reflex action occurs. The main source of the reflex action is through the bottom muscles.
Can you keep writing on this please?![]()
As far as I am aware, it does not.Nitefly - Does the spinal cord store information? You said about if you touch something hot then message goes to spinal cord but not the brain.
We have next to NO idea how the brain works at all.
If it was to evolve it would be by survival of the fittest, it's one of these mutations that would simply occur and since that species in more intelligent it survives and breds. I have literally no idea how it works and would be suprised if we know how it works, but i'm sure it will be worked out eventually.
Look up neural networks, they say that's how it works. How something like that evolves though I don't know, I'm not even sure it does.
What about that blue gene super computer simulating a cats brain, only 100 or 1000 slower...
Thats mad...
I mean would it actually be "thinking" like a cat or what? Would it be feeling alive?
Thats mad...
No, they can simulate the physical number of neurons etc however with no sensory input and no other programming and structure its is simply just a massive storage/processing machine. It is no more cat like than a brick.
