AMD or Nvidia Chipsets
10 Sep 2007
I am thinking of upgrading my motherboard and CPU. I am after an AM2+ board so I can keep my DDR2 Ram.
I am currently on an Nvidia board of some years old, but all the AM2+ Nvidia boards seem a bit dated or expensive. My question is are the AMD Chipsets Linux friendly or should I stick with Nvidia.
I know on the graphics side Nvidia is better then AMD/ATI, buts thats not a problem since I will be keeping by GF8600. I don't anticipate that Compiz will need SLI any time soon so that is not an issue.
I have been eyeing this
http://http://www.overclockers.co.uk/showproduct.php?prodid=MB-199-GI&groupid=701&catid=5&subcat=1482
Your thoughts and comments would be very welcome.
I'm the opposite of the above. I tend to have no issues with NV chipsets (across most Linux platforms). I have had problems with ATI chipsets. Hence I'd urge you towards NV chipsets.
So long as your not using ati's graphics then eithers fine really. Used to run nf4 stuff on linux with no problems and my olf ati based board (rdx200 i think)
You can expect the AMD 7XX chipsets to be pretty rock solid in Linux. Integrated graphics aside. This is more than you can say for nVidia chipsets tbh and the same applies for Windows. I've used way too many nVidia chipset boards to ever go back to them.
Thanks guys, that is great help will probably go for the board I linked to above.
@ NightSt@lker
I have heard intel hardware support is good, they do open source drivers and the like, if I was building from scratch I would go for an i5 rig. Since I have 6GB of DDR2 in the current system the choice is between AthlonII/PhenomII on am2+ or Core2 Due/Quad on 775. I am looking at spending £150-£180 and I think I would get better band per buck on AMD.
This TBH, since it looks like you're buying new parts, the best combination for Linux is Intel chip, intel chipset, and nVidia graphic card.
+1
I was going to run mythtv on my new htpc, I bought hardware based on win7 though!!!
I bough an nvidia chipset AMD board and it is impossible to get spdif working, hence I cannot use linux on it and it stays on win7.
Thats good to hear, I have been looking at some comparisons of Athlon II X4 compare with Q8200 and the Intel doesn't seem to do so well.
The Q8200 is the worst Intel quad, and so I hear it can't clock very well (although I've heard others claiming different - the experiences of all those I know with one are terrible on the clocking front).
The problem with the Q8200 is that it has a very low multi....so even if you manage to get 500FSB out of it that's still only 3.5GHz.
