As track ametuers, something along the MR2 (mk1) or mx5. You'll pick up the former for 500, the latter for a grand in running condition. The MX5 can be turbo'd or supercharged, the '2 will take an sc engine, a mk2 tubby or a 3l V6 from a camry. Read Vix thread on their track activities.
Until you can consistantly get the most out of 120-140bhp/tonne, there is no point going for more powah. Learn to drive first, it will mean you'll get more out of the experience.
The two mentioned will also be a good start mechanically. You can't expect to start messing around with turbo nutter machines and get it right.
Running turbo nutter japmobiles on track can get very expensive, very quickly when you don't really get that much extra enjoyment from having big power on tap. Sticking to something na will be much less bother.
With ref to 'slow' on the track and yourr driving ability - it means jack. You'll be running semi-slick tyres, better suspension, less weight and will find that a decent setup on a smaller, lighter and less-powerful car will run rings around something massively powerful. Once you can handle it in the corners, THEN work on the power. You are coming in as people who aren't mechanics and want to start messing with an M3? Bin the M3 and it will get VERY expensive.
Oh I see! Is it hard to change the gear ratios in cars? Can it be done to most cars easily so it would be something we would learn to do as we go along?Because 0-60 is usually dependant on how many gearchanges to 60 mph and how much traction from standstill. The Golf DSG is a good example of this as the DSG cuts the 0-60 time with a faster gearchange.
In real world, that means a car with less gearchanges and rwd has an advantage for 0-60 but that usually doesn't translate to better laptimes than something else with similar power, weight and grip which may have a way inferior 0-60 because it needs 3rd gear.
Power:weight>paper times for track use.
One last thing, final drive ratio! Most cars are geared for too high a top speed for track use, so a car you can lower final drive ratio easily is also a good thing.
PS. Don't want FWD but considser a Golf???
Any car you will do a lot of work on will help you learn if you are meticulous.
Yeah I think I should actually, although the nearest to me is Mallory Park so I'm assuming it's not going to have a wide variety of car types...Another thing to suggest is go to some track days to watch, you may be surprised at which cars are making the best times.
Surely if you strip out a BMW it would go to a light enough weight to compete with a stripped out hatch or the like? Or is the chasis vital components the weightier parts rather than the "extras" that would be stripped?I would want something far smaller and lighter for the track than a bmw.
I know they're nice etc, I just would be far more interested in something more fun/original.
Mk1 MR2
Mk2 Golf
205 GTi
MX5
7 Replica
Easier to get hold of a half decent example than a 205 or mk2 golf. Main reason for me mentioning them![]()
