Thanks for the help Wayne it is much appreciated. I'm trying to get to grips with this and I have reread your posts many time and learned a lot. Having discussed this with a techy friend of mine - his conclusion is that the mismatched modules is my problem, and it has also been suggested here in this thread. The obvious solution is to buy 2x2GB sticks (unfortunately DDR2 prices are too high atm)
I'm pleased with 980Mhz 5-5-5-15 considering that they are mixed memory sticks.
I'm gonna wind this thread up until I buy matched pair then hopefully you will help me get the best from those. I've learned quite abit about memory - enough to make me consider carefully which mem to buy - voltage, speed and timings and also the number of sticks!
~Scotty
~Scotty
 . . . no wonder you can't set them to 5-5-5-15
