dirt 2 benchmarks dx9 vs dx 11
and i dont think it uses 8AA unless you set it at 8AA then back out of the menu then go back in to run the benchmark, i know it does this with v sync setting, must be a bug in the game
aye it defaults to what u use in game but heres my bench for exterior view
1920 x 1080 8xaa ultra
av 56.9
min 49.9 ? dont know how this has went up!
av 56.9
trouble is with this benchmark is its not a set run, cars can crash and stuff , i ran it once where my car hit a car, it ended up on the bonnet of my car for about 5 seconds or more untill it fell off at a corner lol
I know it sounds a daft question but where do you change what directx version you want to run the game in? There doesn't seem to be anything in the options menu's.
I think you can modify the settings file manually to force it, not entirely sure where it is, but it is probably in my docs/my games sort of area
Thanks Disjunto, I will look it up because i'm sure I could run with more AA and high settings if it was running in dx9 instead.
I sussed it out, goto Documents/My Games/Dirt 2/Hardware Settings...Hardware_settings_config and change the line that says "Forcedx9=False" to "True". I noticed a HUGE boost in performance (around 30fps), but as Greebo says you can't max it out and it doesn't look as nice.
Phenom 2 X3 [email protected]
5770 @ Stock
1920x1080
High setting (low crowd)- No FSAA
dx9 Min 61
Average 74
dx11 Min 45
Average 57
Around 10fps drop with 2xFSAA
Am well impressed with these Phenom II X3's, awesome performance, and would clock much much higher on a better board. Also equally impressed with the 5770, i've noticed upto 2.5 the FSP over my old 4850 in new games.
sig in rig,
all settings at Ultra (or High if no Ultra option),
DX11, VSync Off, 1920x1200
Min: 38, Average 44-45.
I did several runs, at 4xAA and 8xAA, and the difference was marginal - no more than 1fps.
Perfectly playable.
Edit: all stock settings, no OC.
is there not a program what can controls clocks and voltages for none msi 5850 cards... dont really want to flash the bios on my card for warranty reasons... but i'm getting rather peev'd at using 2 programs to overclock my card!
What do you use to overclock?
I have a sapphire 5850, and I'd like to try overclocking it beyond the catalyst limit without flashing the bios
