Performancetest Passmark 7.0 (Benchmark) thread
13 Dec 2003
UK
Hi
I remember using this a looooong time ago as a system benchmark, looks like it has had a make over since v5 or so
so for a laugh lets see how good it is as a benchmark, I don't know if it makes use of hyper-threading, crossfire etc.. but it seems to give give a score for CD/DVD which influences the results, so to make it fair, stick a DVD in the drive whilst running the benchmark ;) and post a picture like I have
(I used the 64 bit version - though I doubt that should make a difference but try keeping with the 64 Bit version if you have the right O/S) and give a brief description of the hardware in the system like I have below, so it makes sense!
Its a 30 day free trial ... but it shouldn't take that long to run the test :eek: :p
http://www.passmark.com/download/pt_download.htm
32-Bit Link
64-Bit Link
Advent 4211 Atom 1.6 with Turbo @ 2GHz, 64GB SSD, Mobile Intel 945, 2GB DDR2, Win7 x86
(no dvd drive), but the SSD helps a lot with the score
oooooh close :p
not bad, bit of a hefty cpu score there, although I cant explain that 4.2 v 4.1, maybe I should clock my cpu down a bit :p
2d clocks might be because of powerplay 157/300 in 2d mode
good results nevertheless :D
Yes, I did wonder about the strange differance in our CPU scores, maybe when a few more people run it we may see a possible reason appearing...my SSDs certainly did no harm to my overall score...
Hmm, I do have all the BIOS power states enabled though so my CPU drops to 2.4GHz during minimal use but 3.5GHz when needed :p
Q9550
8GB DDR2
GTX260 v2 OC
Win7 x64
Gigabyte EP45-UD3P
USB2 DVDRW
CBA upgrading really now since all games get 60fps minimum so will only upgrade for actual next gen probably late 2010 :p
This is my 2nd rig, Q9550 @4.0GHz (Gigabyte GA EP45 UD3P), 4GB ram, GTX 275, 150GB Velociraptor, Win 7 (64bit)
maddness, your CPU score is certainly on the low side
