Could be because I'm in the basement room of an old house?
Do you really want to know?
Had this phone for a few months now, lets be honest, its pretty crap when you get over its features..
It sucks at being a PHONE. Clunky to use the menus, hard to text, drops signal and have to turn off to use etc etc.
I have the HTC_IME file on my sdcard. How do I install it to replace the Magic keyboard? I've seen a comparison screenshot of the two keyboards and the Hero kb looks miles better.Have you downloaded the keyboard from the link in Cyanogen's XDA forums thread? He does state if you have issues then install that one.
Cheers, thought so. Wanted to check just in case there was some complicated procedure.It should be an .apk file so all you need to do is use a file manager, like Linda file manager, and select t in there to install it.
http://forum.xda-developers.com/showthread.php?t=567294
Nice. I'd done everything bar the last sentence.you have to change the default keyboard. let me remeber how and I'll post it, unless you suss it first.
Locale & Text
then check touch input
Then in a text input box do a long press to get the input method box up and in there select Touch Input
All sorted now. Looks much better and more UI sensibly designed.
Are there any other apps apart from ringo that I can use to have a custom text message ringtone?
I ask because for some reason aFirewall seems to stop ringo from working properly.
