Windows 7 window resizing
Don
23 Oct 2005
North Yorkshire
Hi guys,
I think this option is available on Win7 I just can't seem to find it. I want Windows to auto resize my windows when I have a couple of windows open to fit the screen.
I usually have Chrome and iTunes open and want them to auto fill the screen next to each other without me doing it manually.
How do I enable this?
Thanks
If you would like two applications to be open side by side of each other, simply drag one application to the left hand side and the other application to the right hand side of the screen and they automatically resize themselves so one application takes up the left hand side of the screen and the other the right hand side - Windows 7 Snap.
Hopefully that is what you are referring too. :)
This can be done a bit easier using keyboard shortcuts. Select the application you want on the left and press Win+LeftArrow, then select the application you want on the right and press Win+RightArrow. Win+UpArrow and Win+DownArrow maximize and minimize an application, respectively.
