I would download AMD Overdrive and see what it thinks your CPU temp is
Confirms what HW Monitor says unfortunately.
Theron I will try the case on side thing, and yeah thats my mobo.
much better temps
I would doubt the guy who says an AMD chip is fine at 90c, I think that might even be a bit hot for some intel chips :|
It's certainly way to hot for that CPU you start to get instability at around 65c
Phenom II 965 is one of the hottest (most power consuming) "x86" PC CPUs ever so high temps should be expected. (unless temperature sensors are "tweaked")
Actually Prime isn't even that heavy load:
http://downloads.guru3d.com/IntelBurnTest-v2.3-download-2047.html
Errm, not true! I've never heard of one going over 55C before. Mine is on the max safe overclock of 3.8ghz @ 1.5v. (Can't get it any higher), and the highest I've seen with a Fenrir Titan with the fan on about 40% is 50C.
i hav the same board, with the same gpu,cant say my board gets that hot, it max s out at 44*c O/C at 3.5ghz,the cpu cooler is supposed 2 be 1 of the best u can get, my ocz cooler is at best average, could b a case issue, i got the antec 300 and it knocked 10*c of my temps, for 40quid might be worth a go!!
I can believe the temps. Not tried ocing yet as I wanted to get it stable. Under prime95 it was 51/53 which isn't far off yours, but then you don't state wether your highest was under a stress test or just general usage.
I've also yet to get these temps with the case side closed, so may just opt for a different case regardless.
