 - 4 Jul 2009
 - Perth, WA, Australia
9.12's
As far as I can see, these aren't officially available yet...?
9.12's
Perhaps the rest of your system is louder. Your system is only as loud as the noisiest component really.
I've got 2 5770's in mine with the shroud and never hear em?!?!
That is a blatant lie. I also have 2 shroud cooled 5770's and they are very, very loud when running at above 60% fan. Either you have very low expectations or you are deaf. I'm not sure what inspired you to talk such rubbish. I would go with an egg cooler now if I could.
Question: My new 5770 has been giving hard freezes and "driver has stopped responding" errors when I play demanding games or run benchies at stock clocks, yet when I OC it to 900/1295 it runs pretty much fine with only the odd driver fail message. What's causing this and how can I fix it?
Cheers
What happens at football stadiums then.......
Alfie... not wanting to cause an argument and i only have one 5770 myself and i can't hear it. The only time it is auidable is when the pc first boots for a second or two then you can't hear it. Why do you need to run your fan at above 60%..? Mine is stock at 35% with a idle temp of 37oC. OK i see you have two, but i can't see the need even with two, to run at 60%..?
Yeah I tried that but to no avail, yet raising the clocks seemed to help a lot. Was able to play dirt 2 for nearly an hour before I got an error (though it seems to be back in force now)
Fair play. It's probably because the rest of my system is silent and I have 2 that it's loud. I had a GTX 280 before which was quieter than a single 5770, even at 100% fan speed!
Lots of overpaid girls get paid way too much to kick around a ball whilst thousands of yobbos watch them do it.
Hardly a good analogy.
try to stay under 80c at 100% GPU loading and you're fine. These cards are "safe" up to 90c
I use Auto fan, as there's no need to be an armchair thermal engineer, you'll only drive yourself nuts.
Fans only kick up under Furmark at 75C +, but under normal gaming never kick up at all.
Why would anybody but a fool put their fans at 60% for constant use?
