managed to get it sorted in the end - although watched a video of an older CPU without a heatsink attached. They really did blow up!
Was the temperature of the Q6600 before the computer shut down.
Frigging stock cooler with the rubbish plastic things, a leg popped off!
This is "the" video that's been doing the rounds for years now. Critical cooling failures on a Pentium 4, Pentium 3 and two Athlons.
Edit: Love the dual-blower cooler on that Athlon 1400, haha![]()
. P4 on the other hand just kept on ticking.. they demo'ed it with quake running, and as it started overheating it just dropped the framerate massively (as the cpu cut back to about 10% of its normal speed).
, but yeah, only checked the first link then quoted the wrong one
. That toms hardware video is a good oldy, when Toms actually bothered reporting interesting info, and was slightly less biased to any hardware vendors.It's really weird how it took AMD that long to include that "emergency stop" into their CPUs.Done with fireworks naturally, they should have just done the AMD's as P4's had both thermal throttle, and full shutdown and will not burn, and even P3's had a thermal shutdown state at 120 degrees. (Basically all intel chips since P3 have had an omg 120 degrees OFF NOW saftey cutout). Also, even if you disable thermal management in bios (some allow you to disable the throttle state), you cant disable the 120 degree shutdown, its built into the CPU.
No doubt it would have saved life of quite many AMD CPUs.
