Tversity and others....
18 Oct 2002
Nottingham
Hello,
I am running Windows 7 Pro 64 bit and have a PS3.
I want to stream moives, pictures and music to my PS3 over the wireless connection.
I have heard of tversity and used it before on Windows Vista and it was great.
Are there any other like tversity that you recommend ?
Also does tversity.com work on win7 64bit ?
Thanks Ben :)
I use Tversity fine on Win7. Never liked PS3MediaServer me, too much fiddly stuff to tweak, good for some I guess, but I prefer just a couple of options that Tversity has.
Im not sure of the details, but i was under the impression certain versions of windows 7 could handle transcoding without the need for extra software.
If i'm making things up though, Then PS3 media server is your bet choice on PS3. Much smaller memory footprint in comparison to Tversity
Well both tveristy and ps3 media server are not working well for me.
Everything i play just keeps stuttering and fails to play.
Even playing a photo slide show gives errors :(
PLays a moive for 10 seconds then stops.
My PC is more than powerful enough to run the transcode aswell, core 2 duo 2.26Ghz 4Gb RAM.
Any idea or good help site links ?
Thanks Ben
I've just been using Windows Media Player to stream between my x64 Windows 7 and PS3, haven't had any problems so far. If you want to use mkv files or anything fancy it might through up problems but just for video files it's as easy as it gets.
Thanks Ben
Remove all codec packs you may have installed, and don't install the pack that comes with tversity
Install Haali media splitter, FFdshow and AC3filter. Install Tversity\PS3mediaserver.
This should give you a system that will not fail to play most movie types, although I still struggle with MKV, but i blame that on my low system spec
ps3mediaserver definately gets my vote
i've never tweaked anything on it and it works flawlessly :confused:
Too many transcoder options in there for my liking. In TVersity, its either Transcode On, Whenever needed, Or Off. Last time i used Mediaserver it seemed to have a load of options that i didn't know what they did. Could have changed now.
I prefer to simply click "Off" for transcoder when i don't need it or "On" when i do.
it still has loads of options but i've never changed any of them (except for ticking the definately disable subtitles option))
and it only transcodes if it needs to so no need to turn it on or off in the options
Is: "keyint=1:vqscale=1:vqmin=1 /* Lossless Quality, Crazy Bitrate */" better than: "keyint=1:vqscale=1:vqmin=2 /* Best Quality */"
The Best Quality one is above it in the list, so im not sure what the best one to go for is. Over wired connection, so i guess the "Lossless" will be the best?
Hello.
Well i have uninstalled both PS3 Media Server and TVersity at the moment.
Just trying to setup Media Player 12 to stream to my PS3.
All i wanna do is stream my music, pictures and video films from my Toshia HD camcorder.
See how media player works out.
Thanks Ben
Honestly I have no idea, I've never changed any setting in PS3 Media Server.
Which files in particular are you trying to stream?
