- 7 Aug 2004
Hi all, iv just got a drobo, so far, alls good, but im planning on doing the following, is it a good idea and will it be RELIABLE as a backup solution?:
1 drobo with 4x 500gb drives (what I have/can find)
Apple time machine 500gb (drive removed and placed in drobo, western digital green 1.5tb added)
So my plan is, the drobo should give me 1.4tb usable space, the time machine formatted is 1397gb, so pretty much the same (take ages fill it all), I have 3 questions:
1) Obviously if a drive fails in the drobo ill replace it, if the drobo fails however will it work if I buy another drobo and add the drives, will all my data be there ?
2) Ill time machine back up the drobo, so ill have drobos drive failure protection and also another copy of everything on the time machine, if drobo catastrophically failed, can I restore ANY time machine backup to any drive?, also can i restore any folders etc time machine will hold, like if I just wanted to recover my picture files off the time machine onto my mac?.
3) If for some reason Drobo failed, and time machine failed, I know drobo has a proprietary file system and cant be accessed without another drobo, but what about time machine ? for example say its electronics failed and the hardrive was fine, could i remove the harddrive, place it in a caddy and access its contents on my mac without it being in another time machine ?
The drobo btw is my 'main hard drive' it will get used day in day out (holds all my pics, itunes, vids etc), as I have a macbook pro with a SSD drive in it, main use is lightroom etc.
Thanks
Thanks
