Rapidshare account limits
6 May 2009
I have a Rapidshare account, it allows me 5gb a day. I can get something called traffic share 10 euros for 100gb
However to buy another account is only 7euros for 30 days. Im presuming i would get 5gb a day on another account so 150gb, plus my 5gb a day on my current account
Has anyone else used trafficshare or somehow increased their daily rapidshare download? The obvious thing to do would be for me to create a new account and keep switching when they run out but i might be missing something
Thanks
On my rapidshare account I downloaded 24GB+ in a few hours and had no problems, even though it said my limit was 5
Yep, you can save it up from day to day. So download nothing in a week then hammer through 35gb. Log in to your rapidshare account and it will tell you on the information
I got the 100GB trafficshare once as I needed to download 50GB on the first day I had the account. It's only really worth it if you have something big that you need to download and can't wait until you've banked enough allowance.
Dont see how a second account would help as you'd still be only able to download 5GB per day on it. So 10gb per day using both.
Also this is only worth doing if you ADSL can actually download 50GB in one day!
Or you can wait for rapidshare's happy hours where download counts as 10% of the actual traffic, thus you can download 50gb and only use 5gb of your daily allowance. You can schedule any download to start automatically if you are not home/on-a-pc at the time.
Easy!
Easy!
When are these 'happy hours' ?
Cheers
ok - i have just got the trafficshare 100gb. How do i transfer this to my allowance? I have set it to use allowance and it sayd it will use it iff needed but downloads still dont do anything?!
edit - can anyone get onto rapidshare.com now? I just get this
Connection Interrupted
The document contains no data.
The network link was interrupted while negotiating a connection. Please try again.
Phone them up. Their tech support is excellent! I've had to phone them three times. They took note of the problem and ended the call within seconds, then the problem was fixed a few minutes later.
rapidshare or sky? I hear sky block rapidshare sometimes
My 100GB didn't go on until the next day. Their support is great though. My account got hacked on Christmas Eve and they sorted it then.
I done some research cause I am also interested in knowing, and its 2am to 10am CET time,
so 1am to 9am GMT
Think this is right.... confused myself a bit !
Those times are correct. If i have anything big to download i always wait till the happy hours. No need to spend money on trafficshare.
