Aeroplane mode? How do you turn that on?
My battery was rubbish for the first few days, its way better now, this happened to anyone else?
on Nokia's it's called "Flight Mode" - it shuts off all wireless radios (for safety on flights, obviously
you should be able to select it at the profile-change-screen... short-press the power button maybe?
some battery guy said:ordinarily, (especially for things like laptops) it's best to discharge Li-Ion batteries as little as possible. obviously in a phone like this that's not really possible, but its a good idea to charge the battery whenever you have the opportunity.
the reason why a couple of full charge-discharge cycles are required to get the battery to it's highest capacity is because on a new battery, the charge/capacity monitoring hardware has not been calibrated yet, and fully charging, discharging and charging again ought to set this properly. it's probable that the batteries capacity monitoring hardware (i'll explain why it's there in a sec) thinks the battery has less overall capacity then it really has.
from here:
http://forums.overclockers.co.uk/showpost.php?p=15571274&postcount=244
