- 22 Aug 2009
- Nottingham
Why does your cpu-z say 4.189, and you sig 4.4ghz
It became unstable and forgot to edit my sig its been edited now.Why does your cpu-z say 4.189, and you sig 4.4ghz
^^^ could you make that screenie any bigger?!?!
Also, are you saying your idle temps are 6, 10, 3, 8 across the cores?
I find that hard to believe... something's definitely wrong there imo...
snip..
Perhaps he's sharing a fridge with will0812?![]()
...snip...
BTW, Nice rig You've got There
Is the Corsair Cooler any good?
Because im Still using the stock heat sink and , im limited to a 3.2GHZ Overclock?
I might have to look further into this cooling method Danny, I'd love to have my chip running as cool as yours.
I'm curious as to how it's plumbed into your loop though, I don't suppose you have any pics of your setup?
Also, regarding fittings onto the unit, are you able to use any fittings you wish, or does the unit have to be modded to take standard G1/4 threaded fittings?
