Can we have a worse quality picture please?
In some ways 4x4's are more dangerous in the snow as it lets you pick up speed without any hassle. Then you realise how little grip there is when you meet a corner or need to brake.
) I got near the end of the close and braked. Other than feeling like someone was thumping the bottom of my foot with a hammer nothing happened.
Thats your ABS trying to work....I got near the end of the close and braked. Other than feeling like someone was thumping the bottom of my foot with a hammer nothing happened.
First, ABS will only feel different from ordinary brakes when you're braking hard. During “ordinary” braking (i.e., not a “panic” stop), you should brake in exactly the same manner whether you have ABS or not, and the brakes should respond in the same way.
When you initiate hard braking, the anti-lock braking system may be activated. When this happens, you may experience rapid pulsations or vibrations of the brake pedal, it may feel like the brakes are “pushing back at you,” or the pedal may suddenly drop. Also, the valves in the ABS controller may make a noise that sounds like “grinding” or “buzzing.” These are not signs that the ABS is not working, they are signs that the ABS is working, so if you're braking hard, and you this happens, just keep the brake pedal pressed down.
One way to test your ABS brakes, and also familiarize yourself with the feeling of how they work, is to drive your car ( fairly slowly ) on a loose gravel lot ( without any people or traffic ) and apply the brakes hard.
I was going to make a thread on this last week. I've never in my life seen as many retards in 4x4's driving in such a cocksure manner in terrible driving conditions. They seem to exhibit the old "Haha, be gone with you standard car minions, I shall breeze past you in my fit-for-purpose machinery!", not realising that whilst they may have more traction when putting power down, they're actually more likely to end up in a ditch as the cheap Kwik Fit special tyres on their lardy, momentum filled SUV which they remortgaged their house to get, break traction.
My GF lives in Billericay, everyone there seems to drive like a ****![]()
