Hi, im looking at watercooling my pc, ive got a H50 but i want to include the graphics card in the loop too.
Ive currently got an Antec 300 case so a bigger one will be needed, ive looked at the Panzerbox
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-NX&groupid=701&catid=7&subcat=
edit: id like a case with a side window, around the £100 mark, cant justify spending 200+ on a case.
Ive got a GTX 260 card and a Q9550 but will be looking at upgrading this mid 2010 so a multi socket CPU block would be better.
How many/what size rads would i need, will a 240 be enough or should i include a 120 in the loop too?
Was thinking res-pump-240 rad-CPU-120 rad-GPU-res
or res-pump-240 rad-CPU-GPU-res
Is a pump with a res better than a seperate pump and res?
Im at the early stages of putting lists together and have got a few ideas of how to do it, its my first watercooled build so im open to suggestions.
Thanks in advance
Thanks in advance
