about a week maybe just under...Nice clocks here Gareth. How long do you think it's taken you?
well maybe go higher at some point. but for now im happy as it isThat's brilliant I think. Can't estimate how long I've spent on mine, but I have a suspicion I started last Autumn and I'm far from finished.
Happy with 3.9 or hoping to take it higher?
If the stock voltage (amd call this vid?) varies so much and is somewhat unrelated to overclock, does overclock on "stock volts" mean much? Just musing.
It irritates the hell out of me when people run systems which they know won't pass stabilty testing. So here's a rant, clearly aimed at Martini.
That a computer hasn't bluescreened/frozen/otherwise crashed doesn't mean it's running correctly. It only means it's stable enough to not **** up an operation badly enough to crash the system. It can still make minor errors which don't do any obvious harm, until such point as it corrupts something you care about. If it's failing testing then the odds of it making small mistakes you don't immediately notice are much higher than if it is passing.
If your system can't run ibt indefinitely it is not stable. If it runs prime95, ibt, f@h and everything else you ever ask it to, then believe it's stable but be prepared to revaluate this if something goes wrong.
have u tryed prime95 on blend at that too mate?But I still run at 3.9GHZ, I can get it IBT stable on 1.375V,
Thermalright Ultra-120A with 2 fansJust wondering what cpu cooler you guys are using?
some people say prime95 on blend may find the system unstable, where IBT doesn't (i won't say any names,)
Corsair H50 is better but i will never use a watercooling because if it leaks it'll kill the system..Would you recommend that over the Corsair H50? I was really tempted with Corsair but if the Thermalright Ultra-120A is better then I will get that.
Corsair as got abit strong on that nowThat has crossed my mind.
I just started a new thread because I would have thought if that did happen then Corsair would be responsible for the damage caused.
I cant find anything on their site though.
Owned.
I bother to write a piece, primarily for your benefit, explaining that passing one stability test does not mean your system is running correctly. It means it's running better than if it failed, that's all.
You reply with a link to a different thread where you show yourself passing a small number of loops of ibt, tell me I don't read anything, and state owned.
You're evidently quite stupid, so I shall spare myself the bother of reading anything else you write. Best of luck in your gamble against data corruption.
