Unigine DirectX11 benchmark
Hello there :)
Just got myself a Asus 5770 so here is my little effort ;)
Well i tryed my best its gonna have to do till my next big upgrade ;)
I hadn't paid much attention to DX11 until I saw Dirt 2 running on my brothers PC. It is such a jump from DX10 in terms of how things are processed and displayed.. stunning.
There is another good video of the benchmark with a voice over but can't find it just now - will edit this later.
I assume that is with tesselation on ? (captainRAVE)
Same seetings (I think) with a pair of 5870s @ stock:
Stock Sapphire 5970 OC, so looks good to me.
SNIP
Yes, but there will be a slight difference due to the res difference, look at mine above there is an 8.1 (wowzers :P) difference from 1920x1080 to 1920x1200 :D
EDIT Actually thats a c20% diifference, so worth considering :D
Just re-ran after setting catalyst to factory defaults (have had a poke round there to see what the settings do!) and turned FRAPS off ... now got 2 runs at approx 35.6 FPS @ 896 Score .. that's something back! As to the rest ... well, I'll have a play later ..
Got a few more frames back .... :D
Hi can someone check my scores see if there right?
GTX295 @ 650/1200/1400
I7 920 @ 4.0
6GB DDR3 @ 1604
DX10 0XAA and 4XAF 1920*1200 = 39.3FPS
DX10 4XAA and 16XAF 1920*1200 = 29.7FPS
Unigine
Heaven Demo v1.0
FPS: 43.4
Scores: 1092
Hardware
Binary: Windows 32bit Visual C++ 1500 Release Oct 22 2009
Operating system: Windows 7 (build 7600) 64bit
CPU model: AMD Phenom(tm) II X4 940 Processor
CPU flags: 3006MHz MMX+ 3DNow!+ SSE SSE2 SSE3 SSE4A HTT
GPU model: ATI Radeon HD 5700 Series 8.682.2.0 1024Mb
Settings
Render: direct3d11
Mode: 1920x1080 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Unigine
My two Vapor-X in crossfire.
5870 at 900/1300, 10.2 drivers:
Everything maxed out and enabled.
Just wondering why everyone isn't maxing out all the settings, I thought thats what you do so we're all on a level playing field? :)
maybe there should be a new thread started with set pattern to follow then just a screen shoot at the end would make much better reading for example
All setting on high, full screen .x8AA 16AF etc and what a common res now 1680x1050?
maybe saying what cards you used at what clocks and drivers, worth doing?
