I sweat a lot.
Status
Not open for further replies.
Permabanned
9 Oct 2009
To die by your side......
So even after a shower, and deodorant (antiperspirant stuff) I sweat. Now it is probably partly due to me being a bit overweight, but I am working on that, and it is a long term thing, several months. Ideally I would like to stop the sweating asap.
I would like some recommendations on products that are readily available from tesco and not obscenely priced. I don't care if the stuff blocks my pores, I'll just sweat out my arse more, that's okay.
Also, I'm not a stinky person, my sweat doesn't smell and I never have BO, it is just annoying, as it is coming up to summer, which means t-shirt weather, which means I can't lift my arms very high due to massive sweat patches. This obviously causes massive dent in my confidence, due to me knowing that people who see the patches just think I smell and don't shower.
TIA
+1 for Dri-clor.
It makes you very itchy for the first few applications but works excellently.
I used to sweat a lot no matter my level of exertion or temperature and after using Dri-Clor I can wear a shirt all day with no sweat patches. As time goes on you require less and less applications - I apply about once a fortnight and then just use normal deodrant for the bouquet :p
If it is a serious problem, contact your doctor about having botox injetions into your armpits :)
I got it done privately and had it all done within a few weeks, simple 2 min operation, it hurt a little bit, and it lasts up to 2 years!
I need to go back and have it done again now, had it done last december and its great, massive boost in confidence :)
Lose weight, cut your booze intake and excercise 3+ times a week. I used to use Driclor as I used to sweat just sat at my desk with a fan on. Never felt hot or anything and was damn embarrassing. Excercise and next to no booze I have not used it in months
Yes that is the long term plan, but like i said, 4 stone of booze and fat isn't just going to fall off overnight, I wanted a solution for now, and it seems driclor is the solution.
How much does botox cost though, and do i become American if i have botox in me?
There's a newer treatment that I've seen which uses lasers.
It's thought to be a one off treatment unlike botox.
I think it's more expensive but you do it only once so will work out cheaper in the end.
I have no idea if it's available or just in trial stages.
Hmmm interesting, any idea what its called?
DriClor works 100%, i used to be quite bad in the pit area about 10 years ago, literally dinner plates just sitting down, i wasnt overweight either, it stopped it after about 2 weeks of applications, now i dont use it anymore i seem to have either cured myself or the DriClor has blocked me for life... Its about 6-7 quid for a small roll-on which should last you a good 4 months, just make sure u stick to using it on your pits, i know someone who thought it would work all over and used it on his back and face!!
I only really sweat from my ball sack for no reason. No medical responses though, no putting that Driclor near those!
Status
