Hello again. It's been awhile, but things have been pretty hectic. I've finally managed to put the standoffs in the case and screw the motherboard to them.
I've also attached the heatsink fan and used the correct amount of thermal paste (I hope). Though as shown by the yellow circle, I think I may of rotated and attached the heatsink's fan in the incorrect position? Although it does seem to fit properly, and the arrows indicating airflow suggest it should be fine.
The fan's cable is positioned at the bottom of the fan (as indicated by the tiny arrow) if that's any help. Is this lead allowed to touch the heatsink in anyway whilst it's connected to the cpu fan header and the computer is running? I ask this, as at the moment it is hovering between the the case fan's grill and the heatsink. I'm wondering if it might rub against the heatsink during the fan's operation etc.
The hard drive is also installed although it is not positioned the same manner as shown in the build guide. It faces towards the side of the case:
I've installed the hard drive so that its ports are at the back of the above picture:
The exposed circuitry is on the underside of the 3.5 bay. This seemed to be the only way to install it, so I'm hoping I will be fine. I must admit, the Fortress's instruction booklet is not much help for a beginner like me.
If everything is ok, I will now start to attach some of the headers.
