Play it on your PC at 720p, draw distance, vehicle density and detail distance under 20, textures and other effects no higher than medium.
If you get more than 30fps you have better performance than the PS3/Xbox version. Duh.
if you set the same settings on the pc to the console, the console looks better,pc only gets better when you up the resolution,detail etc
(and the frame rate is looooooow)
