- 22 Mar 2009
- Cornwall
thats what the site sayCompatible With INTEL P4, LGA 775, AMD K7, K8,Clip,All for you
thats the fan i had on the 775 in the same case and that fitted if it helps.Heatsink Dimension : 93 x 93 x 98.5 mm
DC Fan Size : 92 x 92 x 25 mm
Base Material : Forging Process
Bearing Type : One Ball
Speed : 3500±10% RPM
Noise Level : <31 dBA
Max Air flow :52.44 CFM
Rated Voltage : 12 V
Weight : 495 g
why do intel ship the stock hsf if it cant cope with stock settings?
I suggest scaling back the RAM speed to 1600MHz, as X58 memory bandwidth is so large - you won't lose any performance.
