Getting a flat pack kitchen fitted
30 Aug 2006
Anyone know a rough cost to getting a Homebase kitchen fitted?
Its about 7 base units, 5 wall units and two work tops (with two joins)
Obviously wont be getting Homebase to fit, id do it myself but i just dont have the time.
Anyone got experience with getting them fitted?
Think I read somewhere that some people do it based on a per cabinet price, but your best bet is to get a few competing quotes from local kitchen fitters, or ask who homebase would recommend. Just out of interest, why didn't you go to a local full-service kitchen fitting company, it may well have turned out cheaper than doing it the way you are.
I've fitted the kitchens in both our current place and our last place and it really doesn't take as long as you think.
Ive been thinking about this. We got a quote from Homebase for the kitchen (which is flat packed), it came to a total price of £6000 then they did all their 'sale' discounts and got it down to £2000, how the hell they did that... im guessing the hike up their prices in January so they can make it seem like you are getting a decent discount.
Ive heard that Homebase fitting prices are about the same price of the actual kitchen itself.
You have to remember that this kitchen is a certain colour that we have not found anywhere else.
We are just starting to phone around the fitters today, the few we have talked to also 'build and fit' their own kitchens, so we will be looking into that as well... but because of the colour its not going to be much cheaper to get the fitter to make/design the kitchen.
Your probably looking at around £300 - £400, the joints are probably the most expensive part of doing any kitchen.
Fitting your own kitchen is not for the faint hearted despite what some might say.
It is only 'not that hard' if you have a practical mind and are good with DIY.
In my experience, kitchen designer supplier and fitter for over 10 years, 90 % of kitchens installed by peeps with a lack of experience turn out un-level, not square and the plumbing is generally poor, compression fittings and push fit couplers are used where solder joints should be used.
Don't get me wrong I am not having a go at those who try it....on the contrary, good luck to you and fair play for doing it.
What I would say is that if you contemplate doing it yourself then get decent spirit levels, not the cheap DIY store plastic things, and a large set square.
If I were to do it then you would be looking at around £500 if it was local.
That would be with seamless routed worktop joints, not the aluminium ones that harbour dirt and bacteria, and Colourfil jointing and sealing compound.
Don't use the glue that they supply with the flat packs, it is pants and you never get enough to do the job properly.
EVO STIK waterproof wood glue is the way to go and get a small set square to make sure that the cabinets are square as you build them.... kitchens are a lot harder to install if the cabs are built out of square and can cost a great deal of time when trying to screw the units together, get them level and be able the get the doors to fit squarely.
DO NOT RUSH IT!!!!....take your time and spend the time getting everything right as a small miscalculation here can have a detrimental effect somewhere else.
As ace2109 said "the joints are probably the most expensive thing" with regards to time and if they are messed up then the whole kitchen is spoiled as messed up joints stick out like a sore thumb.
I'm no expert but I would imagine quite a bit more than that
I would agree but he is only looking the cabinets fitted and the worktops jointed there is no mention of plumbing thats why i said about £300 to £400. That is what i usually charge, if you are looking the plumbing and wiring done your probably talking around £500.
ace
ace
Thats right, the plumbing and power sockets will stay put.
Ill keep these prices in mind when getting quotes.
There are a few niggly bits to 'shape' the cupboards around but nothing to taxing.
If found out that you can get worktops longer than 3m, we need one about 3.5m. Homebase only do them at 3m, apparently we could save a lot if there are less joins in the worktop.
Plumbing may be staying put but bear this in mind....You will still have to plumb in the waste and the taps and if it ends up like a homebase kitchen I recently fitted, although the plan look the same as original fittings, it will be different.
My price above included plumbing etc
ace
Got you, thought the fitting was a full job, plumbing, electrics etc
Plumbing isnt too hard, infact none of it is really hard (infact i enjoy things like this) but its time i dont have. Also if im honest my workmanship will be good but not as good as a pro, some who knows all the tricks to get things to fit perfect and they will do it in half the time it would take me to do it.
Im in Southampton, but ill probably be going through checkatrade.com, at least then ill get some reviews.
Almost that exact same amount of units took me, Including removing the old units, replastering the walls where they were damaged before the old kitchen was put in, re routing the plumbing for the washing machine from one side of the room to the other, AND putting a new floor down, one bank holiday weekend.
<Snip>
Very good advice there. Me and my father both put in the current kitchen. Included tiling, extractor hood, wall units, benches and oven / hob. took total about 4-5 days to do the lot. The kitchen worktops that needed jointing were done by a kitchen fitter. Although I could have bought the gear to do it, what was the point, it wouldn't have been as good and would have cost the same.
It was more difficult getting the bottom skirts on as the floor was not level (Tiled a few years back). Tbh, looks like a professional installation due to the worktop being done properly.
I'd agree with this. I spent about 9 months working with a mate fitting kitchens (he's been doing it for 10+ years) while I was looking for my current job. I'm very practical minded and I found it a challenge each time.
For a very basic kitchen start to finish, design, rip out old one, supply everything, good quality carcases, fit, plumbing, any electrics and tiling would come to £5K-£6K.
He wasn't the cheapest though, everything had to be totally perfect, no bodges and each night the place would be left spotless no matter what mess was made during the day.
I fitted our kitchen recently, it's easy enough if you're that way inclined and take your time. I got solid oak worktops made to measure with all the joints/cuts done though. I would recommend a table and mitre saw though (I have a combination DeWalt one I was given).
How did they fit? I don't think I found one room that was square and each top had to be cut to fit the angle of the room.
